Forums >> Revit Building >> Technical Support >> Revit Monolithic Stair with Material Finishes
2 Posts No Rating |
Hello,
I am currently using Revit 2014 Student Version, and am attempting to build a concrete flight of stairs. I was planning a monolithic stair, having its structure made with concrete and have certain material finishes to it, such as dry bit on the underside and maybe some stone for its treads, yet I am having trouble finding a way to apply different materials to it. any help with this would be appreciated. Thanks~!
1 Posts No Rating |
I have the same problem .. Help Please
47 Posts No Rating |
Try using the 'paint' tool.
1 Posts No Rating |
You can change the material of all the components of the stairs (Thread, Riser, Run). Just go to the project browser, find the stair group, under this group you'll find thread and riser types. duplicate and rename a type and then change it's material. make sure you change the stair monolithic type properties to match the riser or thread type you've created.
Hope it helps!
CAN'T MAKE MONOLITHIC STAIR |
Fri, Feb 5, 2016 at 10:16:19 AM
13
Monolithic Stair with Stringer |
Wed, Aug 5, 2009 at 10:43:25 AM
Curved monolithic stair problem |
Thu, Mar 11, 2010 at 2:33:32 PM
Monolithic Stair Question |
Thu, May 26, 2011 at 7:14:40 AM
Monolithic stair - large construction height error |
Thu, Oct 13, 2011 at 12:10:34 PM
Members: | 2115069 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
