62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Attach Wall base via object list?
Tue, Aug 6, 2013 at 1:07:45 PM | Attach Wall base via object list?
BobbyLala
Is there a way of attaching a wall to a reference line via an object list (as opposed to picking the reference plan in your view)? My problem is that I have drawn an angled reference line in one view and rotated in a perpindicular view - effectively angling my reference plane in two directions (?) But with it being rotated it isn't planar to the original view it was created in and I can't physically select it on screen to attach other walls to it.
I've attached some images to try and explain it better. I'm using Revit 2013. Open to suggestions!
122876_NORTH_ELEVATION.jpg122876_WEST_ELEVATION_01.jpg122876_WEST_ELEVATION_02.jpg122876_BEFORE.jpg122876_AFTER.jpg
Tue, Aug 6, 2013 at 1:16:36 PM | Attach Wall base via object list?
Create a new view that allows you to see the reference plane and the wall, then attach it.
You do know that you can rotate vertical sections?
Wed, Aug 7, 2013 at 12:58:49 AM | Attach Wall base via object list?
BobbyLala
No - didn't know you could rotate vertical sections! That worked though thanks.
So, to conclude; As long as I rotate a view that's parallel to my reference plane ( in this case my section) to the same angle I'll be able to attach my walls through that view.
Cheers!
How to attach top/base - walls to mass roof
Tue, Sep 22, 2015 at 3:18:06 PM
Curtain Wall Fails to attach to Roof by Face object
Mon, Jan 25, 2016 at 1:43:03 PM
Attach Wall up to Roof
Tue, Oct 2, 2007 at 3:57:58 AM
Wall Base Offset... one works, one doesn't. Why?
Wed, Jun 10, 2015 at 2:53:53 PM
Revit newbie - Tapered circular column will not attach top/base properly
Thu, Aug 22, 2013 at 5:26:47 PM
Page generation time: 2.3569
