96 Users Online (95 Members):
Forums >> Revit Building >> Technical Support >> finding object
3 Posts No Rating |
hi.i want 2 objects for using in my project.i searched them but it had noresult.they are:1.litracon block or cube(it is a light transmittingconcrete)2.spider fitting.please help me how can i find them fordownloading.i recently joined to revitcity.thank u
Post some images about what you need/want please...
![5 Stars: 3 Votes](/images/stars_5.gif) |
hi 1270314521
1.draw a wall with desired thickness. the thing is u need to create new material. you might want to use a jpg for your texture. convert that texture into a black and white jpg for maps. use your help (F1) to guide you to create your material with maps (transparency, illumination).
2. i guess your looking for glass connector, spider type: http://www.revitcity.com/downloads.php?action=downloadnow&object_id=3615&object_file_type=rfa
** dont be mad, i dont have much... i am homeless |
3 Posts No Rating |
hi ronmalit
thank u very much for your helping
i know how to create a material.surely u know that litracon shows light and shadows of somethings that are back of it if i create litracon in this way it will be seen shadows that are in jpg that i use not shadows of objects in my work!!!!!if see a image of litracon u will understand.
and aboat the spider fitting:i had the spider connector,i wanted the complete spider system:glass-wall with spider connector:D
and finally i found it !!!however thank u again
3 Posts No Rating |
hi typhoon
i learned revit
i'm in a hurry to finish my project .i used some new materials in my design and have no time to create them in revit.thank u for your attention and wishing, learnning more and more.....is good
suggest u search the image of litracon and spider fitting in google image ,it causes u know more and more and more materials,it's usefull for u typhoon!
Finding Consultants who use Revit |
Thu, Mar 10, 2016 at 1:45:54 PM
Embedded Detail Component and Object Styles |
Fri, Feb 12, 2010 at 3:21:25 PM
Selecting/Finding Specific Level |
Thu, Aug 7, 2014 at 8:57:04 AM
Object parameters |
Mon, Jul 28, 2008 at 12:53:06 PM
Finding "Select All Instances in Project" |
Fri, Oct 30, 2015 at 12:42:39 PM
Members: | 2022494 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
