77 Users Online (75 Members):
Forums >> Community >> The Studio >> Ceilling work
3 Posts No Rating |
I'm new with revit, and very familiar with 3D and cad. I'm trying to make a reflected ceiling grid. I have a few questions, how do i insert fluorescent light fixture in the grid and/or also other accessories as ventillation objects. My second question is: can we rotate the ceiling grid.
Thank you for your help. I'm glad that there is a Revit community.
![quiller Avatar](user_avatar/665.jpg)
![2.5 Stars: 3 Votes](/images/stars_2.5.gif) |
Welcome to Revit.......
Go to a refelected ceiling plan and insert the light fixtures. I'm assuming you found the light either in the imperial library or on this site. Any other accessory can be added to the ceiling in the same manner as long as it was created using the ceiling faimily. If you have and object going through a ceiling and its was not created in the ceiling family, you will have to edit out the ceiling in the area.
3 Posts No Rating |
Thank you quiller for your input
I will try that out
''you will have to edit out the ceiling in the area''. hum...
35 Posts No Rating |
What Quiller means is thatyou need to create a "hole" around any projection through a ceiling otherwise the ceiling will still be shown in section.
To do this when making a ceiling you could use the "pick walls" tool then use the sketch tool to trace around a chimney for example.
Hope this helps.
----------------------------------- AutoCAD & Revit TAFE teacher from regional Australia |
5 Posts No Rating |
I think this relates to my problem that I posted yesterday. What if the ceiling grid goes through the suspended linear light fixture? Do I need to cut a hole in the ceiling? In the RCP view, most fixtures cut the ceiling underneath them on their own. I don't get why just the suspended linear fixture doesn't? I have attached the fixtures to see if anyone that has more experience with families can help.
Ceilling plan views |
Wed, Feb 26, 2014 at 7:31:12 AM
ceiling |
Mon, Feb 20, 2006 at 7:16:47 PM
Demo Ceiling grids |
Thu, Oct 23, 2008 at 2:17:39 PM
8' ceiling in a 6'2 t.o.w. |
Sat, Sep 6, 2008 at 11:21:56 AM
I want to know how to work with work set |
Tue, Jun 15, 2010 at 7:11:11 AM
Members: | 2017238 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
