50 Users Online (49 Members):
Forums >> General Discussion >> Revit Project Management >> Work sharing only works on one computer
87 Posts No Rating |
I created two user files: User A and User B. However, when try to open User B file on another computer (computer B) it says the file contains an incorrect schema...I thought to try to create the user B file from computer B from the central file but computer B does not recognize it as a central file. I know I was able to do this before but for some reason I cant this time. Help
Also, I am using dropbox. I thought maybe this was a path issue so I made sure that the path was the same on both computers. But is still does not work.
Maybe I shouldnt have but I had to create a new central from a local file because the local file at one point would not sync with the central...
Well, I'm sure I've confused everyone by now...
I don't believe you can use dropbox with a central file. Please re-read your help on worksharing.
What do you mean? My file was started in the drop box.
Revit by default always creates a central file in the C drive. But even when I copied the central file in the drop box, it worked before.. now it does not work at all.
Read this subject in your HELP:
Implementing Server-Based Worksharing from File-Based Worksharing
Worksharing in revit means that all computer must have the same path to the central file. The central file has to be only 1 file to handle real time managment of keys and permissions. Therefore we have tested and concluded that Dropbox cannot be used to host the central file (there are a few websites that also show that central file cannot be shares using dropbox). Are you working on a local area network or sharing a project over the internet?
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Work Sharing with School Projects |
Mon, Jan 16, 2012 at 8:48:37 PM
I dont want to mess up my computer. |
Wed, Mar 9, 2005 at 3:07:46 PM
Revit MEP computer hog |
Fri, Mar 28, 2008 at 8:02:23 AM
Revit to CAD text issue |
Sat, Feb 25, 2012 at 7:40:09 AM
Violation Sharing |
Thu, May 24, 2012 at 8:33:18 AM
Members: | 2030517 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
