78 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Parts of grouped elements have dissapeared after setting a workset
Thu, Aug 1, 2013 at 3:32:17 AM | Parts of grouped elements have dissapeared after setting a workset
Zlata
Need some help here Smile
Yesterday we have set up a workset at work to share the project that have been going on for a while. And today I have discovered that some elements, that are a part of a group, are not showing on any views, not plans not 3d. But it you select the group then you can see that they are there. How to fix it? and what have caused it?
 We have checked with my colleague if maybe its a workset fault, tried to sync couple of times. but he sees the same problem.
See attachment.
Thanks for all the answers! Smile
Thu, Aug 1, 2013 at 6:27:53 AM | Parts of grouped elements have dissapeared after setting a workset
Why would you group all of that together?????   Please read up on the use of groups.
Do you have one instance of one group or multiple instances of the same group?  Your views don't really tell us.  If you have multiple placements of a group (which is what groups are meant for), then portions of the group may be included when placed.  This is usually caused by hosted objects that can't find a host.
Thu, Aug 1, 2013 at 7:13:57 AM | Parts of grouped elements have dissapeared after setting a workset
Zlata
I have several buildings in this project and all are in a very conceptual phase. So I grouped this one in order to make it easier and faster for me to move the whole thing around, while the urban planning is going on.
The problem is the columns that have dissapeared from the group. When you select the group you can see them(as is showen on one of the pictures), otherwise they are not there. When I open a group to edit it, then they are not there either.
Thu, Aug 1, 2013 at 7:29:44 AM | Parts of grouped elements have dissapeared after setting a workset
Ah-ha .... columns ... And you initially had grids - correct?  Columns associate with grids and when you move the building....no grids to place the column.
This is a poor use of groups.  You are better off to have everything on from a plan view set above everything with an infinite depth ... and with grids on.  Then window the area and move everthing.
Edited on: Thu, Aug 1, 2013 at 8:08:07 AM
Thu, Aug 1, 2013 at 7:37:18 AM | Parts of grouped elements have dissapeared after setting a workset
Zlata
Grids! Of course!! Its been a looong day!
Thank you Winking
Curtain Wall & Room Bounding Dissapeared
Mon, Jun 27, 2011 at 9:36:36 AM
Parts v cut profile
Wed, Feb 8, 2017 at 11:01:08 AM
revit 2014 grouped unit- interior elevations
Fri, Apr 10, 2015 at 8:02:49 AM
Excluded parts showing up in 3D -revit 2014
Mon, Jan 6, 2014 at 1:56:29 PM
Parts in IFC without door/window opening
Tue, May 12, 2015 at 10:08:24 AM
Page generation time: 2.2703
