57 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Breaking a Jogged Section Line - Hiding Central Portion
Wed, Jul 31, 2013 at 6:41:28 PM | Breaking a Jogged Section Line - Hiding Central Portion
calev
In Revit 2012, I have a jogged section line that I want to break (so that the section line does not go through the drawing, but appears on either side of the building in plan). Once I've broken the section callout line, I'm able to drag the two sides outside of the building. However, the central portion of the section line (where it jogs) is still there, and I can't find a way to get rid of it. It's just a floating line in the middle of my plan, and I would like to make it disappear if possible.
Thu, Aug 1, 2013 at 6:19:24 AM | Breaking a Jogged Section Line - Hiding Central Portion
It is not possible ... at least I have never seen or found a way.
Thu, Aug 1, 2013 at 5:52:35 PM | Breaking a Jogged Section Line - Hiding Central Portion
calev
I figured it out finally. You can use the split tool to break the central portion of the jogged central line. Then you can drag the middle points to the outer endpoints. The line becomes nonexistent and pretty much disappears, but you are still left with two tiny dots that mark the ends of the central section line. Much better than seeing the whole line!
Adding gaps to jogged section lines
Tue, Sep 3, 2013 at 10:08:40 AM
Creating a 'Jogged' Section Line
Tue, Dec 11, 2007 at 8:26:06 AM
Section variations
Wed, Jul 19, 2006 at 5:05:09 AM
Section Box Jog?
Mon, Dec 6, 2010 at 5:54:33 PM
Section line angled?
Sat, Jan 20, 2007 at 10:45:03 AM
Page generation time: 1.4431
