50 Users Online (49 Members):
Forums >> Revit Building >> Technical Support >> SPOT ELEVATION ISSUE TO STAIR LANDING
2 Posts No Rating |
Morning all,
I have a problem when attempting to place a spot elevation to a stair landing in plan view (See attached image). The spot elevation does not recognise the placement, although all of the treads in the view can be assigned a spot elevation (All landings have been modelled correctly). I have read a few other threads regarding this issue, all CAD links are disabled, I have tried to create a plan region also with the cut planes amended but this doesnt seem to work. The edge of the landing is not recognised either.
The model is linked into a documentation model where all of the annotations are assigned, I thought this may have been the issue, however; I tried to assign the elevation in the origional model and it still doesnt recognise the landing. Please note that this is a component stair (which shouldnt realy have much bearing on the issue).
I hope I have explained myself clearly and would appreciate any kind of help to try and find the solution.
Thanks in advance,
H
This may be a component stair bug. I have no problems with normal stairs.
2 Posts No Rating |
Same here, may be another one to ad to the list it seems. Appreciate the response.
Cheers,
H
how to show stair landing level with "spot elevation" |
Sat, Mar 17, 2007 at 7:47:16 PM
Editing Profile of Stair Landing |
Mon, Mar 3, 2014 at 2:36:37 PM
stair railing transition at landing issue (2015) |
Wed, Sep 16, 2015 at 9:29:50 AM
Starting a Rail on the stair landing. |
Thu, Dec 19, 2013 at 3:01:59 PM
Spot elevation tag issue |
Mon, Jun 3, 2019 at 3:18:37 PM
Members: | 2022361 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
