Forums >> Revit Building >> Technical Support >> Where is the systems menu in Revit 2014
When I upgraded from Revit 2012 to 2013- I really liked the systems menu where I can now add mechanical and plumbing features. But now it's missing in 2014. Is it missing or turned off?
Under the big "R" go to Options>User Interface and turn on the tool tabs you are missing.
Arcross the top in 2013 has Architecture, Structure & Systems.... The systems menu that allows you add ductwork, pipes, an cable trays is missing in 2014. It doesn't showup in user interface.
Wow - you don't even take a minute to look!
Do as teafoe has written!
i think 2013 was the first year they did they combine "suite" where all three disciplines were included in one. Is there a chance that your upgrade to 2014 was architecture only?
Thank You. I had Revit Achitecture 2014.
Hi guys,
I also found it the same way on my Revit 2016. As you see my attachment, I don't see "Systems" Tab next to either "Architecture or Structure" Tab. When I open the "Option" from "R" logo on the top left corner; I can't find "Systems" under the User-Interface.
Can anyone please help me out with this?
Thank you,
Sorry, but it is not available in your Revit version. This little ‘A’ under the big ‘R’ stands for ‘Architecture’. Systems are not available in Revit Architecture. Only Revit so-called ‘one box’ has all three flavors.
I have a little 'S' under the big 'R' revit 2016 but also cant find the system tab?
You have Revit Structure. Afaik, systems tab is available only in Revit MEP and "one box".
