58 Users Online (57 Members):
Forums >> Revit Building >> Technical Support >> Walkthroughs in Revit 2013
I just installed Revit 2013. I created a walkthrough path on the sample building and I can't find the playback or editing controls. The WikiHelp is useless.
29 Posts No Rating |
tazman1- Wikihelp is not useless.see this link http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/2164-Walkthro2164/2167-Editing_2167
let me know if it's helps.
I read this before. Am I overlookng thewalkthrough panel? See Attached.
Step:1
First create a walkthrough and finish it off.
Step :2
In Project browser, you can see Walkthrough.double click and you get the walkthru window.
Step:3
Click tht window.you can see top Edit walk through click that.. you can get key frames in Left Corner.
Step : 4
Click tht upto your start point. your play button is turn on... press the play button then animation is running...
Enjoy...
How to play walkthroughs |
Fri, May 7, 2010 at 1:51:57 PM
Revit 2013 Walkthroughs different sizes? |
Tue, Aug 21, 2012 at 10:35:37 AM
Revit model into Max and rendered with Vray!?? |
Thu, Aug 15, 2013 at 4:51:40 PM
Rendering Walkthroughs [ 1 2 ] |
Thu, Jul 16, 2009 at 3:03:37 PM
18
Rendered Revit Walkthrough Wavy! |
Wed, Feb 9, 2011 at 10:45:14 PM
Members: | 2042244 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
