78 Users Online (77 Members):
Forums >> Revit Building >> Technical Support >> DWG Export Setup for particular layers?
4 Posts No Rating |
I am trying to export a DWG file from Revit2012 to include a different layer for each room fill color that we have used (see image).
I need to output different colored and named layers for each of the departments as we have specified in the room identity data, so each color fill area in the DWG is on a separate layer associated to its particular department. The desired CAD layer name might look something like this: A_Color Fill_DepartmentX
We have a full Revit to DWG layer output file established, but it seems that it is not possible to associate each department to their own individual layers? At present the DWG file outputs all of the room fills to the same layer like this: A_ ColorFill
Can anyone help with this? I have tried to include images for reference.
Thank you.
You are correct - not possible from Revit.
4 Posts No Rating |
Thank you for the response.
Export all properties BYLAYER, and create new layers for overrides. |
Fri, Nov 14, 2014 at 12:22:28 PM
dwg export duplicate layers |
Tue, Dec 3, 2013 at 3:29:32 AM
REVIT 2013 - Export DWG Layers Text File Location |
Fri, Aug 3, 2018 at 4:44:52 PM
Dwg export: revit 2013 ignoring subcategories |
Thu, Jul 25, 2013 at 8:12:43 AM
Keep .dwg Layers when exporting .rvt to .dwgPlease |
Wed, Feb 24, 2016 at 9:27:59 AM
Members: | 2056445 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
