61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Importing autocad civil data! Whats best for Revit 2012
160 Posts No Rating |
Can anyone tell me what I should ask for from my (Australian) surveyor for him to send to me to import into Revit 2012. I think he is using Civil 3d
I am currently opening a file of his into my Autocad 2011 but the contours are a "proxy" which does not seem to be read by Revit.
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net |
DWG format ideally. The open the DWG in AutoCAD and delete anything you dont need. Check the scale is correct, purge, audit and save and import into Revit.
revit structure 2012 add-in "integration with civil 3d": routing error? |
Wed, Jan 25, 2012 at 2:56:13 AM
dimension change when importing AutoCad file |
Thu, Oct 16, 2014 at 10:59:01 AM
Import full Civil 3D 2012 model in Revit Architecture 2012 |
Thu, Jan 26, 2012 at 6:23:35 AM
REVIT'S POOR GRAPHIC DESPLAY WHEN IMPORTING AUTOCAD FILES |
Sun, Sep 24, 2006 at 10:37:21 PM
Importing LandXML to Revit |
Sat, Dec 11, 2010 at 2:59:51 PM
Members: | 2030517 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
