31 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Calculated Value in Schedule controling an Instance Parameter
Fri, Jul 19, 2013 at 4:43:26 PM | Calculated Value in Schedule controling an Instance Parameter
iamian33
iamian33 Avatar
RAC 2013:
Can a Calculated Value in a (Door) Schedule control an Instance (yes/no) Parameter in a (door) family?
I trying to use set up a door schedule that will compare information about the rooms and set an instance parameter within the door family.  I have found this statement on various blogs but I am unclear of the syntax to use it:
  • Force checked = 1 < 2
Specifically, the 2 adjoining rooms are compared to set 'TRL Room'.  If either room is 'YES' I want to set TRL Door (checked).  When this instance parameter is checked the door schedule will show 'T' in a schedule column and that instance of the door will show a symbol in plan and elevation.
Thank you
Ian Shafer
Principal Consultant
True North S&F Consultants
Calculated value
Fri, Aug 6, 2010 at 2:17:20 PM
getting a calculated value parameter into a shared parameter for tagging
Tue, Feb 2, 2010 at 1:58:26 PM
Calculated Values
Mon, Mar 3, 2008 at 11:01:18 AM
Calculated totals of formula in schedule
Fri, Sep 11, 2020 at 7:14:08 AM
Keynotes & Door Schedules - keynote field - change to instance parameter?
Fri, Oct 17, 2008 at 3:47:43 PM
Page generation time: 2.4690
