62 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> true north and plan north effect on sun angles
Thu, Feb 9, 2006 at 12:17:00 PM | true north and plan north effect on sun angles
hgm
I have a plan with true north rotated 39 deg from project north. I have created perspective views using the camera process and create a scene with specific settings for a time and place. When I render it the sun angles are not based on true north but appear to be oriented to the project north. I have tried creating the camera views utilizing plan views that are oriented to both true and project north. It doesn't seem to matter. I have also turned on the shadow setting (bottom left of work screen) and set shadows to a specific time and place. In this case the shandows are based on true north. Why the discrepancy, am I missing a setting in the rendering system? This is criticle because I am design shading devices for an existing home and need to show the client what will actually happen.
Thu, Feb 9, 2006 at 5:40:35 PM | RE: true north and plan north effect on sun angles
eldados
eldados Avatar
4.5 Stars: 8 Votes
in your render setting, is "use sun and shading from view" ticked? if so un tick and see what happens... Smile
Integrator
KarelCAD
Mon, Feb 13, 2006 at 7:45:07 PM | RE: true north and plan north effect on sun angles
hgm
yes the setting is NOT checked for "use sun and shanding from view". Maybe I can clearify my problem. In the site plan view I use the button on the lower left of the image area that is "shadows on/off" clicking on this pulls up list in which I select "Advanced Model Graphics" and then select "Sun and Shadow Settings" from here I pick a precise time and date. The shadows look accurate. I then create a camera view and when displayed as a model (just a line drawing, no rendering, but with shodows on) the shadow angles look the same as the site plan discussed above. At this point I select settings from the rendering menu and create a scene with the exact same location, time and date as in the "shadows on/off" setting for the site plan. When I raytrace the image the shadow angles change and are not the same. I have set the angle rotation for true north to project north at zero to eliminate any conflict with this variable. I have also tried setting directly the Azimuth and Altitude values to make the two shadow and shading match and they don't. Any thoughts. I hope this makes some sence to someone. Thanks for any help
Mon, Feb 13, 2006 at 10:13:18 PM | RE: true north and plan north effect on sun angles
eldados
eldados Avatar
4.5 Stars: 8 Votes
if that's the case than TICK the "use sun and shanding from view". Smile
Integrator
KarelCAD
True north help
Tue, Jul 21, 2015 at 3:52:05 PM
Are 3D views automatically set to true north?
Mon, Dec 27, 2010 at 3:14:02 PM
Project North doesn't rotate back after changed to True North
Fri, May 7, 2010 at 3:24:15 AM
True North vs Project North Linked dwgs
Thu, Mar 10, 2016 at 10:02:27 AM
Rotate true north
Wed, Jan 24, 2018 at 4:21:00 PM
Page generation time: 0.5736
