59 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Tips & Tricks >> Concrete Pier @ Corner of an Exterior Wall
Thu, Jul 18, 2013 at 7:53:23 AM | Concrete Pier @ Corner of an Exterior Wall
warrior2304
Does anybody know how to show the corner of the wall to not show up where the pier intersects it?  I have tried a wall opening but that doesn't work.  I have also tried a shaft opening but that doesn't make the wall dissappear at the shaft opening.
Sun, Jul 21, 2013 at 1:19:26 PM | Concrete Pier @ Corner of an Exterior Wall
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
View range possibly? In-place void extrusion?  Join geometry?
Edited on: Sun, Jul 21, 2013 at 1:19:40 PM
Mon, Jul 22, 2013 at 8:23:40 AM | Concrete Pier @ Corner of an Exterior Wall
Are you cutting the view where the pier actually intersects the wall or above that.  If that is the case, maybe you want a plan region.
Tue, Oct 8, 2013 at 12:59:19 PM | Concrete Pier @ Corner of an Exterior Wall
warrior2304
neither of that worked.
Sat, Oct 25, 2014 at 10:06:46 PM | Concrete Pier @ Corner of an Exterior Wall
ladrillero
5 Stars: 3 Votes
You mean for the column to cut the wall? I ran into the same problem before so I played around with settings.Maybe this document from web i put together can help.
Creating concrete stairs from raised exterior slab
Sat, Oct 25, 2014 at 10:26:44 PM
Corner guards to snap to corner of wall
Tue, May 13, 2014 at 12:18:45 PM
concrete panel system not sure what the best method it *****picture included
Fri, Jun 27, 2014 at 8:31:05 AM
wall sweep inside corner
Mon, Dec 18, 2006 at 9:07:05 AM
Wall wrap at insert problem
Tue, Jul 29, 2008 at 3:29:36 PM
Page generation time: 1.4112
