53 Users Online (52 Members):
Forums >> Revit Structure >> Technical Support >> Analytical model edge cannot have a length of zero (0) error
2 Posts No Rating |
I recieving this massage "Analytical model edge cannot have a length of zero (0)"
i cannot delete or modify the wall, how to resolve this problem
2 Posts No Rating |
I also received this error message when trying to create a floor slab. I tried copying another slab and editing the shape, which went fine, but then when I went to move it into the correct position the error message persisted. This error message also made the options bar a bit buggy as the options disappeared after that; saving during the edit mode prompted the options bar to come back up again (after dismissing the 'changes won't be saved' window).
The best solution I found for my floor slab was unchecking 'Enable Analytical Model' and 'Structural' from the instance properties of the slab. I don't need them enabled so that works fine for me, but am curious as to how the error evolved in the first place. Any thoughts?
Resetting/fixing the analytical model (Revit Structure 2014) |
Wed, Jan 15, 2014 at 8:56:48 AM
Analytical Error Message |
Thu, Jul 18, 2013 at 5:15:39 AM
Problem with adding analytical lines into Generic Model line template |
Wed, Apr 10, 2013 at 3:31:06 PM
Revit 2017 No analytical model for curved wall |
Fri, Feb 17, 2017 at 4:59:55 PM
Deactivate Analytical Truss and Slab |
Wed, Feb 9, 2011 at 8:10:56 AM
Members: | 2017300 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
