117 Users Online (115 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> rendering help
Thu, Feb 9, 2006 at 11:30:44 AM | rendering help
hammer87
hammer87 Avatar
3 Stars: 4 Votes
i am having some rendering problems. what it does is that it only renders the top poration of the darwing in 3d and i have two levels, main and walkout basement. it doesnt render anything below level 1, the rest is just all gray.
Thu, Feb 9, 2006 at 12:09:22 PM | RE: rendering help
FlyinHigh
1 Stars: 1 Votes
to add color to the sky in the bottom half go into setting and change the sky setting so that there is color. i dont know about the house not rendering, they may be connected
Fri, Feb 10, 2006 at 8:04:08 AM | RE: rendering help
hammer87
hammer87 Avatar
3 Stars: 4 Votes
ok well i also have objects and other stuff bleow the house level. but ill try the sky settings
Fri, Feb 10, 2006 at 8:57:42 AM | RE: rendering help
K-Pax
Hammer, The problem you are having is due to the Ground plane being rendered and obscuring your model. You will want to make sure these are either set at the proper level, or turned off all together. These are global and go to 'infinity', so they have a tendency to get in the way, other than on flat sites. It's there as an option to placing topo or a flat plane for your site. I'm also assuming you're using 8.1 (similar for the others.) Make sure you to to the following areas and check them BOTH. 1) Rendering Tab (on the left) > Settings > Environment > Advanced (at bottom) Groundplane (Uncheck box) 2) Advanced Model Graphics (little icon at the bottom of the main model window) > Cast Shadows (check box) > Sun and Shadow Settings (click the arrow located to the right) > Ground Plane (at the bottom of the new dialogue box) - make sure it's not checked. This should clear up the grey plane. In versions prior to 8.0, there was a bug that made it difficult to turn the Rendering Ground plane off. If this is the case, make it so its elevation is LOW enough, and place an element around your building to represent your site (could be a Floor element). Hope this helps, Kyle Post edited on 2006-02-10 08:59:57
re: design studio
orlando, florida 32803
www.re-ds.com
Fri, Feb 10, 2006 at 10:51:12 AM | RE: rendering help
hammer87
hammer87 Avatar
3 Stars: 4 Votes
ok ill try that and by the way, im using 8.0. my school hasent upgraded
Realistic Rendering [ 1 2 ]
Thu, Aug 4, 2011 at 2:30:38 PM
25
2 Days Rendering...38% Complete 2009 Slow Rendering [ 1 2 ]
Wed, May 13, 2009 at 7:36:40 AM
22
09' Rendering Issue
Wed, Jun 3, 2009 at 4:22:52 PM
11
Going from Rendering in RA 2008 to Rendering in RA 2009
Mon, May 11, 2009 at 4:32:51 PM
help with rendering!
Wed, Aug 10, 2016 at 10:47:18 PM
Page generation time: 0.3227
