Forums >> Revit Building >> Technical Support >> Problem: Gutters / Cutting Walls and Roofs (not footprint)
4 Posts No Rating |
Good day, I have some problems with Cutting Walls and Roofs / Gutters:
You can see in the picture what my model looks like ("what I've got") and what I'm trying to get ("what I want"). By the way, I want to get that in 3D:1. You can see that in the below picture ("what I want") the insulation is cutted when it reaches the gutter. How can I cut the insulation.2. I also have to make a sloped cut on top of the wall. The issue is: Can I make a cut in a wall not by a footprint in the elevation but in the section of it? (Cut profile is not what I want, I want 3D). I was trying with a mass, but I couldn't.
Thank you.
There is no reason to model elements that should be detail items. For 3D purposes, you can model the 'gutter' in the roof face using a void sweep but everything else I would do in a 3D section cut. Learn to use edit cut profile. Under the view tab - you can read about that in your HELP.
4 Posts No Rating |
Hello WWHub, the Cut Profile tool is fine when you need 2D details, but I need an axonometric view (this project is for university, I'm student in architecture).You said: For 3D purposes, you can model the 'gutter' in the roof face using a void sweep How can I do a Void Sweep on a Roof Element? That's what I want to do.Thank you.
In this instance, I would create an in-place family - void sweep - set the category to roof, pick your roof plane as the work plane - sketch your path then your profile (must have a view to do this - a perpindicular section?) then before you finish, set the void to cut the roof.
4 Posts No Rating |
That's a fantastic solution. I'm doing that, the only problem I have is that I don't know how to set the void to cut the roof.How to do that?
Gutters |
Mon, Jun 5, 2006 at 2:08:11 AM
whole project: walls, floors and roofs for laser cutting and building a physical |
Tue, Jun 18, 2013 at 7:43:15 AM
Simple roof problem |
Thu, Feb 2, 2012 at 5:56:48 PM
Roofs Same footprint - different slopes |
Tue, Apr 1, 2014 at 8:03:45 AM
Problem with roofs and parapet walls |
Thu, Mar 29, 2007 at 4:55:44 PM
Members: | 2119380 | Objects: | 23205 | Forum Posts: | 152300 | Job Listings: | 3 |
