37 Users Online (34 Members):
Forums >> Revit Building >> Technical Support >> Revit Library Access Problem
2 Posts No Rating |
Hi,I cant reach any library files in revit. I meant at materials Autodesk Library, at components, at templates etc. I copied a 2013 programdata files of Revit, it contains some of these files but i figured now its not enough to use material part of Revit healthy.I cant find any materials which i want to attend.If there is a way to find Autodesk Materials as one folder or materials that produced by users, please tell me that cause i am so close to lose my mind.
I asked this to my friend and he told me that i need to go control panel>programs then install the libraries i want from there. But when i try this it wants revit 2013 architecture disk. I am not sure to burn a rac13 disk then continue for fix this problem. What can you say about this in addition?
![Beaucoupnice Avatar](user_avatar/46219.jpg)
![3.5 Stars: 6 Votes](/images/stars_3.5.gif) |
Big R Button ( top right) Options - file save path tab - set file save path to wherever your revit library folder was placed when you installed revit.
managing revit content library |
Thu, May 3, 2018 at 8:37:26 AM
Revit content library |
Mon, Dec 10, 2018 at 10:28:32 AM
Revit Problem Access Denied |
Thu, May 6, 2004 at 2:04:14 PM
Accurender situation |
Fri, Mar 30, 2007 at 1:34:58 PM
Custom Material Library Problem |
Wed, Nov 13, 2013 at 4:18:49 PM
Members: | 2026126 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
