34 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> angled corner joint - how to lock angled corners
Wed, Jul 17, 2013 at 8:27:12 AM | angled corner joint - how to lock angled corners
irfan77uk
Hi,
I have a corner joint which is attached to the end of a glass panel in a curatin wall panel.  How do i lock the angled extrusion so its size stays the same when loaded into the project?  currently when i load it in...it becomes far bigger than i want it.
Please help!
Wed, Jul 17, 2013 at 10:18:08 AM | angled corner joint - how to lock angled corners
neomaxmaya
5 Stars: 2 Votes
Edit the profile shape, then align it to the reference lines and lock them.
Wed, Jul 17, 2013 at 10:52:40 AM | angled corner joint - how to lock angled corners
irfan77uk
do i draw the reference lne in an angle too?  and how would i then lock the reference lines?
Wed, Jul 17, 2013 at 11:11:03 AM | angled corner joint - how to lock angled corners
neomaxmaya
5 Stars: 2 Votes
Yes, you draw the refrence line the way it suppose to be. then you edit the profile shape and you align the shape to the reference, once you align, a lock image shows on the center of the element usually, click it to lock the shape to the reference. close you shape and voila!
Wed, Jul 17, 2013 at 11:26:16 AM | angled corner joint - how to lock angled corners
irfan77uk
you make it sound easy... but honestly...i am still struggling with it! have spent hours trying to figure it out!
still cant seem to align and lock the reference lines in an angle.
Thu, Jul 18, 2013 at 1:34:25 AM | angled corner joint - how to lock angled corners
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
i think it will be much easier to get answers if your family attached.
want more?
You can get more tips at Enjoy Revit
Thu, Jul 18, 2013 at 2:31:33 AM | angled corner joint - how to lock angled corners
irfan77uk
I have uploaded my family...please help
Thu, Jul 18, 2013 at 2:44:38 AM | angled corner joint - how to lock angled corners
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
the profiles of the extrusion has no constraint with ref planes.. just make constraint.
and if i were you, i'd use one sweep void instead..not two extrusion.
by the way.. is this detail really nessasary???
Edited on: Thu, Jul 18, 2013 at 2:48:04 AM
Edited on: Thu, Jul 18, 2013 at 2:49:03 AM
want more?
Thu, Jul 18, 2013 at 2:59:24 AM | angled corner joint - how to lock angled corners
irfan77uk
How would i make the constraint with the angled ref line?  Also i could make it a simple triangle, but thought id make it look as close as the real product.  Can i be cheeky and ask you to add the constraints for me?  as i know i will struggle.  if you can...that would be much appreciated...
Thu, Jul 18, 2013 at 3:12:42 AM | angled corner joint - how to lock angled corners
irfan77uk
I attach the project file, where i test the family... you will notice the error i am refering to.
Thu, Jul 18, 2013 at 3:47:24 AM | angled corner joint - how to lock angled corners
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
whe you want to make angle constraintion, don't use ref plane, use ref line instead..
ref planes have no center point for angle, but ref lines can have it.
try with ref line.
i'd like to fix it but this family is too complicated for someone not created this to handle..
want more?
Thu, Jul 18, 2013 at 5:10:12 AM | angled corner joint - how to lock angled corners
irfan77uk
THANK YOU. Your advice about the ref line helped!
Thanks
Angled window opening in plan view
Thu, Aug 15, 2013 at 2:18:13 PM
11
Curtain Wall Systems- Best way to round corners?
Thu, Aug 19, 2010 at 3:03:22 PM
Making Angled or canted walls
Tue, Jun 3, 2008 at 2:10:08 PM
Angled Window (angled jambs on both sides)
Wed, Apr 13, 2011 at 9:48:15 PM
How do I add a countertop to the Base Cabinet - Corner Unit Angled?
Tue, Mar 28, 2006 at 3:39:11 PM
Page generation time: 0.8324
