81 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Creating concrete stairs from raised exterior slab
Tue, Jul 16, 2013 at 5:18:21 PM | Creating concrete stairs from raised exterior slab
ctonge
Been searching around but I can't figure out how to make concrete stairs step down from an exterior raised slab. Canthis be done with the stair function?
Details:
-slab is around 3ft off the exterior ground - supported by foundation walls.
-slab takes on an L shape and wraps around 1 building corner.
-I need 2 stair runs and they need to connect @ the outside corner, see attached PDF.
-Stair railing needs to connect to horizontal run on slab.
Wed, Jul 17, 2013 at 8:26:12 AM | Creating concrete stairs from raised exterior slab
Use the stair function.  Stairs can start from a level or at an offset from a level (+/-) and can end at the same level or offset from that level (+/-) or go to another level (+/-).  No need for a floor to do this.
Thu, Jul 18, 2013 at 10:15:50 AM | Creating concrete stairs from raised exterior slab
ctonge
how do i wrap the stairs @ outside corner though?
Wed, Jun 11, 2014 at 9:32:44 AM | Creating concrete stairs from raised exterior slab
DebraB88
Did you ever find a solution to create this exterior concrete stair/ L-shaped tread?  I am having the same issue, and I have tried using Stair by Sketch to draw the L-Shape risers, however, I keep getting an error.  How did you build the staircase to meet the top of the 3ft. concrete slab?  I'm trying to acheive the same results... an Exterior Precast Stair at a corner of the building with a 3'-0" concrete raised platform.
Edited on: Wed, Jun 11, 2014 at 9:38:48 AM
Sat, Oct 25, 2014 at 10:26:44 PM | Creating concrete stairs from raised exterior slab
ladrillero
5 Stars: 3 Votes
Revit not easy with some stairs. This video may help you.
https://www.youtube.com/watch?v=z6tOcX2Tzak
Concrete Stairs with winder
Fri, May 30, 2014 at 7:27:59 AM
Creating Raised Floor systems
Thu, Nov 13, 2008 at 11:49:32 AM
Concrete Beam and Slab
Mon, Jun 3, 2013 at 2:47:32 PM
RAISED FLOOR WITH UPSTAND
Wed, Jan 21, 2015 at 7:55:33 AM
show concrete only
Sun, Nov 18, 2012 at 10:16:22 PM
Page generation time: 0.4937
