40 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> inserting objects into "Existing" phase
Fri, Jul 12, 2013 at 2:41:09 PM | inserting objects into "Existing" phase
vanderloo
Somebody please tell me there's a way to set your doors, windows, walls to insert as existing vs. new construction.
I'm getting sick of inserting an entire floor plan and having to go back and change everything to existing in my existing view.
Thanks
Fri, Jul 12, 2013 at 2:45:46 PM | inserting objects into "Existing" phase
Look at your view properties.....set your phase under phasing.
BTW - Learn to use your Help.  If you had simply searched "Phase" you would have found:
Phasing Workflow
This workflow describes a typical method of using phases and phase filters to manage a project.
  1. Determine the phases of work that you want to track for the project, and create a phasefor each.
    Example
  2. Create one or more copies of a view for each phase, and name these views appropriately.
    Example
  3. For each view, in the Properties palette:
    Example
  4. (Optional) Specify graphicsfor elements that are existing, new, temporary, and demolished.
    Example
  5. (Optional) Specify the Phase propertyfor each element.
    More
  6. (Optional) Create phase-specific schedulesfor the project.
    More
  7. Create phase-specific construction documents.
That would have saved you a whole lot of time.
Edited on: Fri, Jul 12, 2013 at 2:47:29 PM
Fri, Jul 12, 2013 at 3:06:14 PM | inserting objects into "Existing" phase
vanderloo
Thanks WWHub
Seems it's always something I've done before but, not being an every day user, you find yourself re-learning alot.
Thanks for helping me figure it out.
Iit's all good now.
Cheers
Maintaining "Phase Demolished" properties.
Thu, Jun 18, 2015 at 8:19:39 AM
When I copy an "existing" element it reverts back to "new construction."
Mon, Jun 16, 2008 at 2:38:24 PM
Ceiling grid lines will not show in the "existing" phase
Thu, May 14, 2015 at 8:14:52 AM
Render problem in 2009 with existing phase
Thu, Aug 28, 2008 at 2:55:45 PM
Drawing in phase
Wed, Jan 9, 2008 at 4:48:50 PM
Page generation time: 1.7621
