Forums >> Revit Building >> Technical Support >> Lights in a Revit Family?
10 Posts No Rating |
Hi all,
First off, I'm using Revit LT 2014.
I've created a storefront sign for the company I work for, and created the sign as a family and bring it into each project as a Component.
I'm wondering if I can add potlights somehow to the bottom of my signbox? Usually it doesn't let me add potlights wherever there is no ceiling installed, so wondering if there is a way around it.
Thanks to whoever answers, for your time! Much appreciated.
Jay
Use a light that is NOT ceiling hosted. There are faced based lights. You can also create a light and nest it in your sign if it is internal.
This user is online |
How do I know if a light is ceiling hosted (where does it state that) ? I need a recessed can in the bottom of my signbox.
Can you place the fixture anywhere or only on a ceiling? That tells you right away. Or you can edit the family and look.
Well I am trying to install potlights in the signbox, so I assume all of them are ceiling based. Is there a way to turn it off from being ceiling based?
Sorry - there is not.
Anytime you have an object that is recessed, then it needs to be hosted in order to cut the host. A lot of users have quit using ceiling hosted in favor of face based families but that can only happen from when you pick the template. You will have to find a face based or build one using this ceiling based as an example. << A good learning process.
Revit always renders all of the lights |
Fri, Aug 8, 2014 at 9:24:36 AM
artificial lights not rendering |
Tue, May 7, 2013 at 6:52:56 AM
External street lights |
Mon, Jun 6, 2011 at 12:11:52 PM
exporing revit 09 to 3ds max with lights??? |
Tue, Jun 2, 2009 at 5:53:27 AM
Revit 2009 Lights |
Mon, Jul 28, 2008 at 4:43:50 PM
Members: | 2126057 | Objects: | 23225 | Forum Posts: | 152298 | Job Listings: | 3 |
