85 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Warning Message question
Wed, Jul 10, 2013 at 2:08:33 PM | Warning Message question
TGarner
I modeled a family of pre-cast concrete beams and loaded them into my project. The family is shared, and I started with a rectangular beam downloaded from Autodesk Seek and modified it, then changed the dimensions for each type and did a Save As. When I try to place an instance of the beam into my project, I get the following warning message:
Can't create this kind of element in this view in the current mode.
I have tried 3D views and floor plans, and switched disciplines from mechanical to architectural to structural to coordination, but no luck - same warning every time.
I searched the help topics, but I'm not finding anything useful.
Any idea what I'm doing wrong?
Thanks,
Traci
Wed, Jul 10, 2013 at 2:22:17 PM | Warning Message question
Goto the correct plan view, click on the structural tab and pick beam, select your beam from the dropdown and place it.
Wed, Jul 10, 2013 at 2:43:56 PM | Warning Message question
TGarner
Sorry, I forgot to specify the version I'm using - I'm in MEP 2011, and I don't have a structural tab. I can switch to Structural discipline, but that doesn't add anything to the ribbon. The only way I can place a structural component is from the home tab, I think.
Wed, Jul 10, 2013 at 3:19:15 PM | Warning Message question
Well gee - that does make a difference.  Our field relies on good communication......
In VG in your plan view, check the box to show all disciplines - make sure all your structural items are on.  I don't have MEP 2011 so just guessing.... Set your discipline to structural then see if you can place a beam component.
Consistency Checks warning message
Mon, Jan 16, 2012 at 4:17:34 AM
Project Sharing Warning Message exceeded "Number of People"
Thu, Dec 3, 2015 at 7:01:52 AM
Warning Message When Placing Mass
Sun, Jun 5, 2011 at 12:00:27 PM
Annoying Warning When Opening Revit 9 files
Tue, Jun 6, 2006 at 6:45:20 PM
PLACING ROOMS WITH ERROR MESSAGE ABOUT ADJUSTING LIMITS 2016
Tue, Oct 4, 2016 at 9:09:34 AM
Page generation time: 0.4813
