128 Users Online (125 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Interior Elevations - 4 callout bubbles combined to single callout bubble?
Wed, Jul 10, 2013 at 1:20:10 PM | Interior Elevations - 4 callout bubbles combined to single callout bubble?
cprepula
I have a project going with and had a person new to revit create the interior elevations in the model. But before I could catch/correct the problem we had 4 interior elevation callouts, each with their own sheet callout bubble. Is there anyway to convert individual elevations to tie into one elevation sheet callout bubble? The elevations have already been cleaned up and noted, so remaking each elevation would be very time consuming. Any suggestions would be greatly appreciated.
You can see the attached image to see the added clutter the multiple bubbles add to the plans.
Thanks
Wed, Jul 10, 2013 at 2:19:30 PM | Interior Elevations - 4 callout bubbles combined to single callout bubble?
coreed
coreed Avatar
4 Stars: 16 Votes
I would just try to align and lock them together.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Jul 10, 2013 at 2:19:51 PM | Interior Elevations - 4 callout bubbles combined to single callout bubble?
No way to combine but since they all refer to the same sheet, you can place them on top of each other.
Making new views is easy.  Just
  1. use one of the bubbles to create the new view,
  2. open each old view, one at a time, window, use your filter to isolate the items to annotations, linework, dimensions, text, tags - etc - all 2D items
  3. - copy to clipboard and
  4. move to the new view and paste aligned same place
  5. - done.
Now delete the old view then place the new view on your sheets.
Wed, Jul 10, 2013 at 4:38:42 PM | Interior Elevations - 4 callout bubbles combined to single callout bubble?
cprepula
I tried copying the notes and masking region over, but was unsucessful.
Wed, Jul 10, 2013 at 4:40:21 PM | Interior Elevations - 4 callout bubbles combined to single callout bubble?
cprepula
coreed: I can align to any part of the elevation tag.
Wed, Jul 10, 2013 at 4:51:02 PM | Interior Elevations - 4 callout bubbles combined to single callout bubble?
Johnzo142
You can create an elevation tag that references one of the existing elevation views and place it where you want it. Be sure to check the reference other view box and select the view you want to reference before placing it. Once it's placed, select the tag and a check box for the other 3 directions should appear. Click one box and it will ask you which view you want that particular direction to reference. Do the same for the remaining two boxes and you should have one tag pointing 4 directions with the approriate elevation callouts. Then all you need to do is hide your original elevation tags. Hope this makes sense. You'll have to edit type the referring tag to remove the 'Sim' text as well.
Edited on: Wed, Jul 10, 2013 at 4:56:33 PM
Edited on: Wed, Jul 10, 2013 at 4:57:58 PM
Edited on: Wed, Jul 10, 2013 at 5:05:58 PM
Edited on: Wed, Jul 10, 2013 at 5:06:33 PM
Edited on: Wed, Jul 10, 2013 at 5:07:11 PM
Wed, Jul 10, 2013 at 5:08:00 PM | Interior Elevations - 4 callout bubbles combined to single callout bubble?
Johnzo142
Can't seem to get two images to post so here's the second one.
Detail Callout Bubbles and Dependent Views
Thu, Aug 12, 2010 at 6:51:10 AM
Clipping Callout Bubbles when clipping View
Thu, Jan 3, 2013 at 6:24:11 AM
Callout Detail Occurs @ Multiple Locations. Anyway to place detail bubbles...?
Thu, Jan 21, 2010 at 9:09:24 AM
bubble callout tag
Thu, Jul 17, 2008 at 3:00:41 AM
Changing line weight of callout bubbles?
Thu, Sep 21, 2006 at 2:38:28 PM
Page generation time: 0.6496
