83 Users Online (82 Members):
Forums >> Revit Systems >> Technical Support >> Splitting Systems by Floor Level
18 Posts No Rating |
If you model MEP systems by floor level, will revit calculations work properly when linking the files? For example, if a section of your first floor mechanical system needs to connect to the second floor mechanical system in order to perform an accurate load calculation will that work if the two models are seperate but linked in a common file? I'm curious as to how people have handled these type of modeling requirements.
Any response is greatly appreciated.
Thank you,
GW
Gregory Williams, AIA, LEED AP
Why are you modeling them as 2 different MEP models?
I am not and don't recommend it myself, but I am trying to find out if this is possible with the software. Do you know? This has been brought up in our office before in reference to very large projects and how one would go about reducing the file size. I've heard of teams dividing/sectioning discipline models vertically, but want to find out if you could do it horizontally and still use the calculations feature.
Splitting the ground floor slab? |
Thu, Dec 12, 2013 at 10:44:54 AM
Site Elevation to Floor Level Problem |
Wed, Jun 27, 2012 at 11:42:30 AM
Isolating Systems |
Fri, Jul 12, 2013 at 3:59:14 PM
I made a Level without a floor plan... but now I want one. |
Fri, Dec 5, 2014 at 4:47:53 PM
Floor Plan associated to wrong level... |
Fri, Jul 2, 2021 at 3:23:05 PM
Members: | 2030550 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
