69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> The Studio >> Room Tags in RCPs
Wed, Feb 8, 2006 at 4:27:56 PM | Room Tags in RCPs
algis01
Does anyone know how to make room tags appear in RCPs? It seems like it would be a simple operation. Copy paste does not work. Maybe it is the way that I have applied the room tags in the plan views?
Wed, Feb 8, 2006 at 4:47:53 PM | RE: Room Tags in RCPs
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I"m having no problems placing room tags in RCP's here and copy and paste works...? Are you cutplanes a bit odd in your ceiling plan - in the sense they aren't cutting through the correct room...?
Wed, Feb 8, 2006 at 5:22:58 PM | RE: Room Tags in RCPs
algis01
I THINK THE PROBLEM IS THE ROOM SEPARATION AREAS, I'M HAVING TROUBLE CONTROLING THEM AND THE ROOM TAGS ARE NOT RESPONDING TO THEIR CORRESPONDING ROOMS...IS THERE AN EASY WAY TO ADJUST OR CLEAR THE ROOM SEPARATION AREAS?
Wed, Feb 8, 2006 at 8:44:52 PM | RE: Room Tags in RCPs
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
select one, right click and choose select all instances, then delete them.... NOTE: THIS WILL EFFECT ALL VIEWS and all your room tags that are using the lines.
Sat, Feb 11, 2006 at 3:03:53 PM | RE: Room Tags in RCPs
algis01
i got the tags to work properly, thank you
ROOM TAGS
Fri, Jul 29, 2011 at 8:25:59 AM
Select room tags; copy rooms to new phase
Thu, Jun 29, 2006 at 7:19:49 AM
Room Tags on Demo Plans
Mon, May 9, 2022 at 3:23:13 PM
Want to see Room Tags but not Rooms
Wed, Oct 5, 2016 at 11:37:52 PM
Vanishing room tags
Tue, Sep 6, 2005 at 5:54:22 PM
Page generation time: 0.7885
