30 Users Online (29 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Panels with Different Finishes on Same Wall
Mon, Jul 8, 2013 at 8:49:20 AM | Panels with Different Finishes on Same Wall
CHAsports
Please see attached image. I'm trying to create 3 different panels each with a different material on the same wall. They are separated by Wall Sweeps. Any suggestions on how to show this? I was thinking a curtain wall, but then how could I insert the single hung windows shown?Thanks!
Mon, Jul 8, 2013 at 8:55:08 AM | Panels with Different Finishes on Same Wall
3.5 Stars: 395 Votes
Normally, we would just split the face of the wall and paint the different materials but you will have a problemdoing this because of the wall sweeps.  I don't believe Revit will like you splitting the face at the same location as the sweep but you can try.
If that doesn't work, consider using an in-place family to replace your sweeps.
Mon, Jul 8, 2013 at 9:09:55 AM | Panels with Different Finishes on Same Wall
CHAsports
Splitting and painting worked! Thanks WWHub!
Mon, Jul 8, 2013 at 9:13:53 AM | Panels with Different Finishes on Same Wall
coreed
coreed Avatar
4 Stars: 16 Votes
Let's see a shot of the result.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Jul 8, 2013 at 9:19:13 AM | Panels with Different Finishes on Same Wall
CHAsports
It's not fancy... but here it is. Hopefully it'll look nice once it's rendered.
Creating a wall finishes schedule, and coding wall finishes on elevations
Fri, Jun 1, 2012 at 4:06:32 PM
Internal Wall Finishes
Tue, Mar 25, 2014 at 4:18:18 PM
wall finishes by room
Tue, Apr 19, 2005 at 11:40:25 AM
Wall finishes and grade
Tue, Aug 31, 2010 at 12:33:10 AM
Multiple Wall Finishes.
Thu, Dec 12, 2013 at 11:02:29 AM
Page generation time: 0.7388
