57 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Toposurface Outline
Sun, Jul 7, 2013 at 9:33:04 AM | Toposurface Outline
ronario
I am trying to create a toposurface with the "place point" method. I am unable to outline the area of the surface, the inner outline points are ignored. I have an overlap of two surfaces. Can anyone suggest a better way to create inlets within a toposurface outline, or perhaps a better way of creating one? I am using Revit 2013 and I am a fairly new user. Please help!
ronario
Sun, Jul 7, 2013 at 11:45:01 AM | Toposurface Outline
"...I am unable to outline the area of the surface..."  << The surface will be created to your extreme points. You don't outline anything.
"....the inner outline points are ignored...."  << I don't know what you mean here.  All points will be used that you create.
"...I have an overlap of two surfaces.." << The only way this can happen is if you created two seperate topo's.
This is a simple process.  Please just read your HELP on how to create a topo surface.
Mon, Jul 8, 2013 at 1:02:12 AM | Toposurface Outline
ronmalit
5 Stars: 3 Votes
hi,
if you want to outline or you dont want the topo (swine) to overlap the slab (floor). you need to split and delete the overlapping/excess.
just want to share this link, it gave me a lot of ideas how to play with topo. good luck.
http://bimtionary.blogspot.sg/2010/02/curb-and-gutter-along-topo.html
** dont be mad, i dont have much... i am homeless
Interior Elevation Bold Outline - Revit 2009
Tue, Mar 14, 2017 at 2:56:01 PM
Flat Toposurface
Thu, Aug 3, 2017 at 8:58:50 AM
Toposurface&subregion problems
Thu, Apr 16, 2009 at 1:47:07 AM
Toposurface in Elevations
Thu, Aug 27, 2009 at 1:51:07 AM
BUILDING OUTLINE
Sun, Feb 25, 2007 at 8:04:30 PM
Page generation time: 0.2612
