90 Users Online (88 Members):
Forums >> Revit Structure >> Technical Support >> Beam Problem
5 Posts No Rating |
Hi all!
I have an interesting problem. I've been working on building the structure of a building with grid lines, columns, and beams. It was all going well until today I noticed that one beam was "missing". Its actually there, I can highlight it, but I can't view it in any view. I've checked all the vvisibility/graphics settings, the view range, everything. It's only one beam and not all the rest. I even tried deleting that beam and redrawing it, which works, but then it "disappears" until I hover over it with my mouse and select it. I have a feeling it's just that location but that doesn't make sense. Help?
Try a new view, not a copied view.
Are you sure there is no object in font of it?
Place a similar beam, same family & size, in another location. What happens?
5 Posts No Rating |
Tried all that, not successful.
There is definitely no object in front of it because I can't see it in any view.
When I move the beam over just a little bit to either the left or right, once it passes the columns, it appears. Placing the same beam family and size in ANY other location works. I tried deleting the columns and putting them in again and one of them works with the beam still appearing there. However, when I put the other column in, the beam automatically "disappears".
Beam alignment problem |
Wed, Mar 13, 2013 at 3:35:35 AM
Problem with beam and wall |
Mon, Aug 29, 2016 at 2:10:28 PM
Beam and joist pockets |
Wed, Dec 22, 2010 at 9:27:48 AM
Beam System problem |
Wed, Jan 16, 2008 at 12:09:21 PM
Meeting Beam Systems to Glulam Beam |
Wed, Jun 20, 2012 at 10:34:16 AM
Members: | 2022461 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
