42 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Conditional statement
Thu, Jun 27, 2013 at 8:17:19 AM | Conditional statement
4ABs
Hi All,
I need some help her if it is possible....I tried to insert a Conditional statement without luck..
What I need is if I check a YES/NO value (Right Stripe) another avlue ( Side Right) change  the value from 2" to 0". Attached is the properties window so you have a better idea....
Thanks 4ABs
Thu, Jun 27, 2013 at 8:51:33 AM | Conditional statement
If (Right_Stripe, 0",2")
Edited on: Thu, Jun 27, 2013 at 8:59:08 AM
Thu, Jun 27, 2013 at 9:14:46 AM | Conditional statement
4ABs
Hi WWHub...Thanks for your fast response....
But now I have a little problem ..I have an ERROR -CANNOT BE IGNORE.....Attached is the window error , please take a look and let me know.
THANKS,
4ABs
Thu, Jun 27, 2013 at 9:22:11 AM | Conditional statement
That error is self explaining......
Change your instance parameters from instance to type or the other ones from type to instance.
Thu, Jun 27, 2013 at 9:58:48 AM | Conditional statement
4ABs
Thank you for your great help...I'm not familiar with programing but after this I will take programing clases or tutorials....Can you sugerst any tutorials...
This is the thing I created a while ago a way that revit can calculate ocupancy based on the BUILDING CODE  ( by room) and work perfect but I have a schedule for plumbing fixtures calculation that it is based on the occ schedule and there is some conditional statements that I need to input  for some uses like BUSINESS ....
Thanks again.
Edited on: Thu, Jun 27, 2013 at 11:38:20 AM
Conditional Statement
Fri, Dec 4, 2009 at 9:49:43 AM
if yes/no statement controlled by if yes/no statement
Tue, Jan 22, 2013 at 4:08:27 PM
Family types - conditional statement
Mon, Apr 18, 2011 at 3:59:51 PM
AAARRRGGGHH! Joist questions!
Thu, Nov 17, 2011 at 12:56:52 PM
Minimum / Maximum Parameters
Fri, Nov 3, 2006 at 2:04:27 PM
Page generation time: 0.6301
