100 Users Online (99 Members):
Forums >> Revit Building >> Technical Support >> Room area + window area
![4.5 Stars: 2 Votes](/images/stars_4.5.gif) |
Hi,
I've been dealing with this problem for a while now.
When i want to make room tag the area is only from wall to wall.
How can i get Revit to add the areal of the window too?
See the picture.
How did you describe your room boundaries? You can use room bounding elements or room boundry lines - your choice.
6 Posts No Rating |
REVIT should automatically detect the highlighted area in red, but it depends on how you modeled that part? It seems like something is not allowing/blocking that area to be included in the area function. Is that a wall or something else. Even if it's a wall, you can untick the room bounding option. See if that helps.
Room/Area report |
Tue, Mar 3, 2015 at 12:58:57 AM
Room tags with area - area not showing up! |
Thu, Aug 16, 2007 at 6:54:26 PM
room area calculations |
Tue, Nov 4, 2008 at 3:48:50 PM
changing the scale of my room and area tags with the scale of my area plan. |
Fri, Oct 22, 2010 at 10:38:38 AM
room area calculation |
Thu, Jan 15, 2009 at 5:51:20 AM
Members: | 2017117 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
