Forums >> General Discussion >> Revit Project Management >> Revit 2014 - Color Schemes disappear when zooming
2 Posts No Rating |
I have applied a color scheme to my floor plan. As I scroll in and out, the colors become chopped up and eventually disappear entirely. When I close the view and reopen it, the colors are completely filled again, but as soon as I zoom or move the view, the same happens. Has this happened to anyone else? If so, advice.
This sounds like a video card problem. Make sure you have the latest drivers installed and that your card is actually supported by AutoDESK.
You may have to turn off hardware acceleration under the Revit R pulldown / options.
Edited on: Wed, Jun 26, 2013 at 12:30:47 PM
2 Posts No Rating |
Thanks for the response. I went through that process and it still continues to have the same problem - and it is only with the color schemes. I am having no problems with filled regions, materials, 3d views, etc.
1 Posts No Rating |
Did you ever find a solution to this problem? I am having the same issue. It is only happening on one level though, my other two levels are fine. I have checked for duplicate rooms (none) and it is only a problem on my machine. On other machines it is displaying fine. Graphics card is up to date and supported, not sure what else to check. Any help would be great!
Revit Spot Elevations, Rooms and Color Schemes Problem |
Mon, Jun 24, 2013 at 12:46:36 PM
area color schemes |
Fri, Jan 27, 2012 at 12:07:14 PM
Color Schemes |
Wed, Jun 3, 2015 at 3:15:19 PM
Color Schemes - Revit 2009 |
Fri, May 8, 2009 at 12:02:05 PM
"System Color Schemes" not regular color schemes in Elevation or Section views |
Mon, Mar 22, 2010 at 6:00:01 PM
Members: | 2099050 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
