58 Users Online (57 Members):
Forums >> Revit Building >> Technical Support >> 2013 Revit Arch - Control wall fill pattern in fine detail mode
Hi! How do you control the wall fill pattern in fine detail mode. I see how to do it in coarse scale fill pattern but cant get the "hatch" pattern out of the fine detail mode. I am trying to show existing walls as simple two line walls and the new walls with the hatch pattern to represent CMU or block.
Thanks for your help.
Rob
Wall fill patterns for fine walls are controlled by the material cut pattern.
WWHub,
Thanks! I will take a look.
Take care,
Rob
Wall assembly layers not showing in fine detail - Revit 2015 |
Wed, Nov 19, 2014 at 12:16:01 PM
Revit 9.1 Detail compontent fill pattern orientation |
Tue, Jan 14, 2014 at 4:18:30 PM
Revit Detail Level fill pattern, Texts in Elevation and Section's Symbols |
Mon, Jul 30, 2012 at 7:12:54 AM
Rotating Fill Patterns |
Mon, Jan 28, 2013 at 8:34:03 AM
Revit 2013 text in coarse scale fill patterns |
Mon, Feb 11, 2013 at 7:27:59 AM
Members: | 2030530 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
