55 Users Online (53 Members):
Forums >> Revit Systems >> Technical Support >> Aligning IES with light fixture
31 Posts No Rating |
I built a custom stage light for some snazzy renderings. The fixture itself tilts up and down and rotates all over the place. What I'm having trouble with is getting the IES to work right.
Is there a way to align the light source with my fixture? I have too many instances to be trying to mess around with a special IES file for each tilt, wattage, etc. It's only 143 of them.
Use "Hide in View" and you're a nazi terrorist who takes the last beer |
![rbcameron2 Avatar](user_avatar/78200.jpg)
![4 Stars: 25 Votes](/images/stars_4.gif) |
3 things:
1) Try recreating the IES based system and remake the Revit file, import it in, and align it from there.
2) Create a reference plane (work plane) for it to attach to. attach and rotate as required.
3) There should be a tilt/angle control. I think by default its set to some pretty odd angles (see attachment)
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here |
I am creating a custom pendant light fixture family in Revit with suspension length set as a parameter that the user can change. My pendant adjusts properly, but the custom IES file does not move with it. I tried creating a reference plane to host it to, but I haven't been able to get it to host. Any recommendations?
Thanks
IES Photometric lighting issue - no light |
Thu, Aug 13, 2009 at 3:30:28 PM
IES FILE AND LITGHT SOURCE NOT IN SAME DIRECTION |
Mon, Feb 6, 2017 at 2:16:45 PM
Custom light fixture w/ ies file rendering help |
Wed, Aug 12, 2009 at 9:20:10 AM
IES files in Revit |
Mon, Feb 6, 2017 at 4:00:14 PM
Opaque light fixture not emitting light |
Wed, Dec 18, 2013 at 3:30:34 AM
Members: | 2022332 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
