74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> grade line
Wed, Feb 8, 2006 at 9:17:15 AM | grade line
gigils
how can i show the grade line in my elevations and sections (something required by many permiting offices)? right now the toposurface is project based not sheet based and it will only be a mass not a line.
Wed, Feb 8, 2006 at 11:23:56 AM | RE: grade line
JSavage
1 Stars: 1 Votes
If you go to the toposurface material's property, go to the cut patten and select 'No Pattern'. In your sections and elevations you will now be left with only the surface line showing, with the depth of the surface masking everything below this line. To increase the depth of your surface masking, check out project settings...
Grade Hatch in Elevation
Wed, Aug 6, 2008 at 12:03:17 AM
Grade Lines in Elevation view not showing
Fri, May 25, 2007 at 5:49:37 PM
show grade line not topo mass
Wed, Feb 8, 2006 at 9:19:36 AM
Grade Line in Elevation
Thu, May 13, 2010 at 3:10:50 PM
Wall finishes and grade
Tue, Aug 31, 2010 at 12:33:11 AM
Page generation time: 1.0149
