64 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Stacked Walls - Can't select wall layers
Mon, Jun 24, 2013 at 1:55:56 PM | Stacked Walls - Can't select wall layers
Archispaz
OK, I know that I've run into this before but can't seem to recall the solution other then coping Reference Lines over.  We have a stacked wall and want to detail it with detail components, all good so far.  That is until we attempt to locate the component to a wall layer or intersection of the wall (internal layers only).  It seems that the stacked wall will not let us select or reference any of it's internal layers, just the exterior.  We then tried to place Reference Lines on them but once again can't select them.  Any thoughts on how to get around or fix this?
Mon, Jun 24, 2013 at 3:14:42 PM | Stacked Walls - Can't select wall layers
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I "Break Up" my stacked walls after they are in place, they just seem easier to work with this way.  Click on the wall, right click and choose break up.
Ajusting layers in stacked walls
Fri, Feb 22, 2013 at 2:44:18 PM
stacked walls not editable
Sat, Aug 17, 2013 at 1:27:28 PM
Temporary dimensions and stacked walls
Wed, Feb 9, 2011 at 8:47:11 AM
Stacked walls on irregular levels
Thu, Mar 5, 2009 at 3:49:36 PM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed
Thu, Jan 24, 2013 at 8:06:07 PM
Page generation time: 1.4520
