74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Saving a copy of a Revit Masterplan file with linked buildings to a new location
Thu, Jun 20, 2013 at 12:36:17 PM | Saving a copy of a Revit Masterplan file with linked buildings to a new location
tellingmary
We want to create a copy of an existing masterplan central file, but there are 105 linked revit model (buildings) Is there a quick way to save a copy with all of the linked files that you can detach and move to another location? Or do we have to save a detached version and make copies of all the links move them to the desired location and relink each file one by one? There are 105 so VERY tedious. Is there something like e-transmit in ACAD or "packaging" in indesign that I am not aware of?
Thu, Jun 20, 2013 at 12:38:24 PM | Saving a copy of a Revit Masterplan file with linked buildings to a new location
If all of the links were set correctly (files in the same folder as the central), then you can just copy and move them all.
Thu, Jun 20, 2013 at 12:42:42 PM | Saving a copy of a Revit Masterplan file with linked buildings to a new location
tellingmary
No there are 2 folders of existing and new buildings that are not in the same folder as the revit central.
Thu, Jun 20, 2013 at 12:54:43 PM | Saving a copy of a Revit Masterplan file with linked buildings to a new location
From your HELP under
Manage Links Dialog:
Path Type
Indicates whether the linked file's saved path is relative, absolute, or the Revit server path.
We always have the linked file either in the central folder or a sub folder that is in the ame folder as the central.  Then all links are relative and everything can be copied.  Now your only solution is to reset every path after copying.
Thu, Jun 20, 2013 at 12:57:35 PM | Saving a copy of a Revit Masterplan file with linked buildings to a new location
tellingmary
Yeah thanks. I didn't set up this file. But it is good to know for future set ups!
Revit 2008 - Linked CAD file changes location
Mon, Nov 19, 2007 at 8:49:59 AM
Revit 2011: Linked model not displaying casting shadows
Tue, Sep 28, 2010 at 1:55:14 PM
topography, building, levels organization and method of work
Sat, Jan 14, 2017 at 11:49:38 AM
Creating CD's from a file with several linked buildings?
Mon, Sep 18, 2006 at 9:33:24 AM
Linked models unload when saving or using workset dialog
Sat, Aug 9, 2008 at 1:47:00 PM
Page generation time: 8.4692
