106 Users Online (105 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Windows not showing in split level floors -?
Wed, Feb 8, 2006 at 3:11:55 AM | Windows not showing in split level floors -?
unicorn
Hi reviteers, I have a split level situation, with the ground floor 750mm lower than the first floor. I am having a problem with the windows on the ground floor not displaying. (some of the windows are around 1500mm above floor level on both floors). I have tried to adjust the view range and view depth by selecting the floor below, as well as adjusting the offset figures, but none of this seems to help. Any suggestions why the problem is occuring, and how to get my windows to display again?
Wed, Feb 8, 2006 at 4:08:33 AM | RE: Windows not showing in split level floors -?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
For split level plans you should use a plan region so you can have separate cut planes for the two levels. This way you can cut all your windows.
Thu, Feb 9, 2006 at 1:56:18 AM | RE: Windows not showing in split level floors -?
unicorn
Good one, thanks Mr. Spot.
Thu, Jul 24, 2008 at 11:22:13 AM | Windows not showing in split level floors -?
rlwells
I have a similar problem.  I have high windows so I have set a plan region around the windows and set the cut plan to cut the window.  The edged of the window and the glass are showing but the mullions and frame are not showing.  I have tried setting the visibility properties in the family but to no avail.  Some of the windows show in one wall but the same window in another wall does not show correctly.  I have tried rebuilding the family.  I have tried deleting and reinserting the element.
Any help?
How do you treat split levels or minor level changes?
Mon, Jun 26, 2006 at 10:40:02 PM
split level homes
Tue, Feb 17, 2004 at 7:04:25 AM
View Range or Cut Plane Settings for Split level and Cape style
Fri, Jul 6, 2012 at 8:19:55 AM
painting split walls with windows
Thu, Nov 15, 2012 at 3:17:05 PM
Mass Floors not all showing up - some missing
Wed, Apr 11, 2012 at 4:44:47 AM
Page generation time: 0.8316
