83 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Revit 2013 floor transparency
Wed, Jun 19, 2013 at 1:08:01 PM | Revit 2013 floor transparency
mark7321
When I place a concrete slab over exterior bearing walls below the walls dissappear completely. Why aren't the walls showing up as hidden lines? My view range is set correctly. Only when I give the floor a 100% transparency does the walls and columns below the slab appear. Problem is they're appearing as solid lines because I made the slab transparent. I need these elements to appear as hidden lines. I could change these elements to hidden in visibility graphics, but I have other columns and walls on the plan that shouldn't be shown as hidden. I updated my graphics card and updated revit with the latest update and it still won't work. I never had this problem before.
Another issue I'm having is I need to turn off the linked architectural model in my structural model before I can annotate any beams with their sizes. When I turn the architectural model back on the beam sizes remain. I'm confused. Are these issues relared?
Wed, Jun 19, 2013 at 1:49:47 PM | Revit 2013 floor transparency
3.5 Stars: 401 Votes
You need to learn more about how Revit works.  Read this in your HELP.
Showing Hidden Element Lines
Wed, Jun 19, 2013 at 2:20:25 PM | Revit 2013 floor transparency
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
I've also found that turning my structural consultants floor to 100% transparent is effectively the same as shutting it off, except that I can measure to it!
Double check course, medium, fine levels of detail.  Sometimes beams/columns are quirky in that sense.
Also, adjusting the view range (at least temporarily) may help alleviate some issues.
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Help: Print transparent objects from floor plan view to pdf in revit 2013
Tue, May 8, 2012 at 2:49:41 PM
Structural floor transparency
Wed, Jul 27, 2016 at 1:28:48 PM
Glass Transparency in Revit 2013
Fri, Aug 10, 2012 at 12:53:00 PM
Turn Off Transparency of Everything?
Thu, Feb 21, 2013 at 1:08:10 PM
Element Graphic Override 2013 - Transparency
Fri, Aug 31, 2012 at 1:57:30 PM
Page generation time: 4.5992
