53 Users Online (51 Members):
Forums >> Revit Building >> Technical Support >> revit 2013
5 Posts No Rating |
Hi I hid levels using right click and then hide. Knoe how to unhide them?
Learn to use your HELP - search unhide and the answer is there.
5 Posts No Rating |
Tried that, was able to unhide hidden elements but not the level tag and lines!! Any more specific help mappreciated.
Paddy
Now that you have a more specific question we can be more specific in our answer. The problem is, you did NOT hide the levels in that view as you said because they don't even show up! Otherwise, they would show when you use the light bulb.
Your problem is the levels don't intersect the view. Find a perpindicular section and look where the levels end. Drag them over until they would intersect your view plane in the other view - now they will show up.
. . . and just to further WW's notes. In order for any Datums (levels, grids or reference planes) to show up in a view the Datums '3D Extents' 'must' intersect the view itself. Floor plans have 'cut planes' and sections and callouts have 'clipping planes'. These cut planes and clipping planes must intersect the datum for the datum to show up in the view.
Also be aware that Datums have 2d and 3D extents. It's the 3D extents we need to work with.
5 Posts No Rating |
Hi,
Tried that and it worked.
Thanks for your help.
P.
REVIT 2013 Materials Library Video Tutorial |
Tue, May 28, 2013 at 5:12:56 AM
13
Problem with Revit 2013 Not Responding |
Thu, Oct 10, 2013 at 12:25:28 PM
11
"auto" open in Revit 2012, when you have both 2012 and 2013 |
Sun, Jul 12, 2015 at 4:52:17 PM
WorksetExplorer for Revit 2013 |
Wed, Mar 20, 2013 at 9:48:16 AM
Upgrading Revit 2010 project to Revit 2013 |
Wed, May 23, 2012 at 1:28:20 PM
Members: | 2066836 | Objects: | 23085 | Forum Posts: | 152272 | Job Listings: | 3 |
