74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> DECORATIVE SLATS TO DUTCH GABLE
Sun, Jun 16, 2013 at 12:49:38 AM | DECORATIVE SLATS TO DUTCH GABLE
P10trek
hi, anyone know what is the best way to create this look in revit is? a larger slat runs around the outside perimeter of the infill. Is there a way to make the wall so it can be adjusted and stretched without needing to move individual battens?
so ideally, a wall or object, that has an individual batten profile for the  boarder perimeter and an additional profile for the horizontal battens that are spaced equally inside the triangle.
Any ideas would be great
Sun, Jun 16, 2013 at 1:06:11 PM | DECORATIVE SLATS TO DUTCH GABLE
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You could use an inplace component extrusion for this
Sun, Jun 16, 2013 at 8:23:16 PM | DECORATIVE SLATS TO DUTCH GABLE
P10trek
as in extrude every piece of timber individually? any tutorials any one is aware of? or someone that has done this before and is will to share that part of their drawings.
thanks heaps
Sun, Jun 16, 2013 at 8:43:44 PM | DECORATIVE SLATS TO DUTCH GABLE
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You can do multiple extrusions in one in-place component.. i would not do this.. i would use a material or paint fir the elevation and use a detail component for the section.
Mon, Jun 17, 2013 at 8:32:04 AM | DECORATIVE SLATS TO DUTCH GABLE
P10trek
have you seen any any tutorials on this? im new to this and not too sure the steps... thanks once again
Mon, Jun 17, 2013 at 9:23:41 AM | DECORATIVE SLATS TO DUTCH GABLE
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Tutorials on create a family?  Look at this http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=14996975  Its from 2011 but it still applies through this release.
dutch gable in roof
Tue, May 29, 2007 at 11:28:04 PM
Dutch Gable Roofs
Tue, May 19, 2009 at 12:35:08 PM
Roof - adding smaller gable to dutch hip.
Tue, Oct 28, 2008 at 11:32:20 AM
"Dutch Gable" roof
Mon, Mar 31, 2008 at 1:35:54 PM
Dutch Gable Roofs...
Thu, Jul 2, 2009 at 1:51:39 PM
Page generation time: 0.3147
