50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Stairs Disappear upon edit sketch mode.
Fri, Jun 14, 2013 at 2:17:11 PM | Stairs Disappear upon edit sketch mode.
fgibase4
4 Stars: 1 Votes
Hi guys. Subject pretty much explains what is going on. I'm new to revit and this is probably an easy fix, but whenever I click on my staircase and then on the "edit stairs" button, the stairs totally disappear. However, after I exit the edit mode, they reappear. I really need to get in there and edit some of the treads.
Any suggestions?
Thanks.
Fri, Jun 14, 2013 at 2:20:15 PM | Stairs Disappear upon edit sketch mode.
3.5 Stars: 395 Votes
Turn on lines in VG.
Fri, Jun 14, 2013 at 2:51:27 PM | Stairs Disappear upon edit sketch mode.
fgibase4
4 Stars: 1 Votes
All lines (except topo) are visible in VG. Anything else it could be? I can attach the revit file if needed.
Wed, Jun 6, 2018 at 12:49:18 PM | Stairs Disappear upon edit sketch mode.
mihu3704
Check your view range. Mine was doing the same. The stiar will show when not editing (even when the view range should hide it). When you edit, the view range cuts the stair out of the view. Change the bottom and view depth to unlimited
Sketch Mode: reference linked dwg lines disappear
Wed, Oct 17, 2012 at 9:59:19 AM
Question about sketch Mode
Thu, Jan 17, 2013 at 6:34:56 PM
RST 2012 RIBBON IS ACTING CRAZY . . . while in sketch mode
Wed, Apr 11, 2012 at 3:36:06 PM
Revit won't (Grey/Halftone/Fade) during any Sketch/Edit/Modify mode
Tue, Feb 27, 2018 at 11:18:53 AM
Can't exit sketch mode
Tue, Oct 22, 2019 at 7:19:00 AM
Page generation time: 0.6032
