91 Users Online (90 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Level Coordination w/ Elevation View
Fri, Jun 14, 2013 at 2:10:12 PM | Level Coordination w/ Elevation View
helli1
I created a level (Level 01)...and either deleted or never created the elevation view w/ tags.
When I realized that I needed to look at the elevation...the elevation tags weren't there identifying the levels.
So, I created elevation tags and it created new levels.  That's fine for Levels 02/03 (which I haven't worked on yet)...but I want to keep using Level 01 as my first floor level.  Crying...the one I created)  But it's not syncing with the elevation tag.
If anyone can make sense of that...I'd appreciate some feedback.
Randall
Fri, Jun 14, 2013 at 4:31:48 PM | Level Coordination w/ Elevation View
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
In order for grids, levels, reference planes, view tags, elevation tags to show up in opposing auxiary view their cut planes and clipping planes must intersect each other. Although your terminolggy is off from what I can deduce the clipping plane of youe elevation does not intersect the boundaries of the plan views / levels.
This concept can be tricky to expalin on screen let alone in a text posting.
Although it is a little dated Cryingbut the theory still stands) what you really need is this video series.
http://www.cadclips.com/REVIT-AC-2008-Datums.aspx
 Your situation is precisely why this training series was developed.
Spot Elevation vs. Level elevation
Wed, Feb 14, 2018 at 6:13:20 PM
BIM coordination role
Tue, Apr 9, 2013 at 4:58:33 PM
Control elevation view - level line
Sun, Apr 2, 2006 at 10:26:29 PM
Revit 2018 - Coordination Models and Printing to Vector
Fri, Apr 21, 2017 at 2:49:50 PM
Level Elevation
Tue, Jul 7, 2009 at 2:39:01 PM
11
Page generation time: 1.0656
