54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Is it possible to make surface pattern IGNORE of the floor slope?
Thu, Jun 13, 2013 at 8:21:28 PM | Is it possible to make surface pattern IGNORE of the floor slope?
danezeq
When making a flat floor in revit there is no problem with the 2d plans.
the patterns (hatches) isn't strangly rotated, and you can always align it with align command.
but if the floor isn't flat - the fight with pattern rotation is endless.
it's just not possible to have a patterns in 2d view with sloped floors.
what's the sulution?
thank you all very much.
Fri, Jun 14, 2013 at 7:16:09 AM | Is it possible to make surface pattern IGNORE of the floor slope?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Use a drafting pattern and in the Modify Pattern Properties dialog box change the oriendation to Keep Readable
Fri, Jun 14, 2013 at 10:43:10 AM | Is it possible to make surface pattern IGNORE of the floor slope?
danezeq
where can i find the option  drafting pattern ?
Sun, Jun 16, 2013 at 3:48:33 PM | Is it possible to make surface pattern IGNORE of the floor slope?
danezeq
i tried to change it to "keep readable" but it does nothing...
no way to do it with annotation somehow? if i do it with "region>>filled region" it hides all components which are on floor. :-(
Sun, Jun 16, 2013 at 7:01:08 PM | Is it possible to make surface pattern IGNORE of the floor slope?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Are you sure you are using a drafting pattern and not model? A filled region will cover modeled components
Thu, Jun 20, 2013 at 10:35:34 PM | Is it possible to make surface pattern IGNORE of the floor slope?
danezeq
yes iam sure. the problem is also shown after render so i'm not sure changing the pattern to drafting will help on render. my main concern is on render.
Fri, Jun 21, 2013 at 7:15:47 AM | Is it possible to make surface pattern IGNORE of the floor slope?
The material pattern only controls the direction of a model material in a render (if there is one).  And as I said in my other posts, the pattern has to be a model pattern if you want to control the material.  The drafting or model pattern doesn't ever show in a render.
Surface Pattern on Modified Floor - No Skewing for Floor Plans
Mon, Sep 12, 2016 at 7:45:12 PM
Floor pattern not showing up when the pattern is model pattern
Fri, Nov 3, 2023 at 9:12:00 PM
Inconsistent Floor pattern for shape edited floors
Thu, Sep 13, 2007 at 11:30:12 AM
Surface pattern problems
Sat, Jul 23, 2011 at 8:29:47 PM
Sloped Ceiling Surface Pattern Not Visibile
Sun, Jun 26, 2016 at 7:21:37 PM
Page generation time: 1.8270
