104 Users Online (103 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Isometric Views & Scale
Tue, Feb 7, 2006 at 5:15:15 PM | Isometric Views & Scale
zaklee
It has been discovered that the scale factor for isometric drawings is incorrect in Revit 8.1. I think it's also wrong in version 8. To correct the problem, you should set a custom scale for the view. The scale factor should be the intended scale factor divided by 1.225. You'll have to round off as the dialog only accepts whole numbers (integers). As an example, if you intend to have an isometric at a scale of 1/4" = 1'-0" (1:4Shadey you would create a custom scale of 1:39 (48/1.225 = 39.18 (~39)). 1/8" would be 1Blushing8. Happy scaling.
Fri, Aug 20, 2010 at 11:18:08 AM | Isometric Views & Scale
BDerrick
3.5 Stars: 3 Votes
I have found this to be true in Revit 2011 too.  The problem is in one direction (x-axis) needs to be scaled by a factor of 1.225 but in the other direction (y-axis) it needs a separate scale of 1.469.  I could be wrong about my calculations but I do know that my isometric views are not to scale.
Isometric Dimensions in Drafting Views (details)
Fri, Sep 28, 2012 at 3:13:09 PM
Revit doesn't show Autocad isometric drawings
Thu, Nov 27, 2014 at 10:27:04 AM
Tag for View name & View scale on section views
Thu, Nov 26, 2009 at 4:45:38 AM
Isometric Details
Fri, Apr 9, 2010 at 1:31:30 PM
callouts, isometrics, and tagging
Thu, Feb 19, 2009 at 8:04:12 AM
Page generation time: 0.6001
