46 Users Online (44 Members):
Forums >> Community >> Newbies >> in place vs. standalone families
6 Posts No Rating |
Just want to clarify on in-place vs. stand alone families and keeping file size down on large projects. If you have an rfa file of the family, it is stand alone. If you don't, you don't. Is that one simple way to look at it, or is it more involved than that? If you use "duplicate" under element properties, you are creating an in-place family. If you use "edit family" and doing a save-as in your project library folder, you're creating a stand-alone family. Is that correct? Thanks
"If you have an rfa file of the family, it is stand alone"<< TRUE
"If you use "duplicate" under element properties, you are creating an in-place family." << FALSE
If you duplicate type of a family then it is just an added type. In essance, you have edited a stand alone family.
If you create an in-place family - then it is an in-place family. If you copy an in-place family, then that is another new - in-place family.
"If you use "edit family" and doing a save-as in your project library folder, you're creating a stand-alone family." << FALSE
You have just altered the family for that project.
Stand alone is a bad term. In-place families are meant to be stand alone - used once. rfa families are multi-use.
Edited on: Thu, Jun 13, 2013 at 1:18:43 PM
Filter for in-place families |
Tue, Jan 22, 2013 at 8:49:24 AM
Materials for in-place families |
Wed, Jul 29, 2009 at 7:07:59 PM
In place families above the view range are still appearing |
Tue, Dec 23, 2014 at 9:17:05 AM
Massing Vs. In-Place Families |
Fri, Jul 17, 2009 at 7:23:22 AM
Why In-Place Families? |
Sun, Nov 21, 2004 at 5:51:42 PM
Members: | 2017266 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
