81 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Adding a General Notes section to our model spashscreen
Thu, Jun 13, 2013 at 8:50:02 AM | Adding a General Notes section to our model spashscreen
MEBDesign
Hi,
I've been creating a 'splashscreen' element to our template file, this forms the screen that will be seen first when opening each file and contains some general information about the file. I want to add a 'Notes' element to it so that the users can write down certain things which will act as reminders or guides for the next time the file is opened.
What would be the best way of doing this would you say?
Thanks
Simon
Thu, Jun 13, 2013 at 8:54:54 AM | Adding a General Notes section to our model spashscreen
coreed
coreed Avatar
4 Stars: 16 Votes
Use a Drafting View.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Jun 13, 2013 at 9:03:50 AM | Adding a General Notes section to our model spashscreen
MEBDesign
THe Spashscreen is a seperate family loaded into the template. Am I able to do that within a family? I can't work out where from.
Thu, Jun 13, 2013 at 9:07:37 AM | MEBDesign
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting MEBDesign from 2013-06-13 09:03:49
Maybe I'm not understanding. if it's a family, you load it like any other family.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Jun 13, 2013 at 9:14:58 AM | Adding a General Notes section to our model spashscreen
MEBDesign
Sorry don't knwo what happened above. Also sorry if I'm not being clear.
My 'Splash Screen' is a seperate family which I have loaded into my template file and acts as the first screen you seen when opening the file each time. I want to set the template up with a General Notes box on this spash screen for users to type small amounts of text to remind themselves of things to do ie. 'Finish changing windows to 900mm cills' etc.
Thu, Jun 13, 2013 at 9:22:14 AM | Adding a General Notes section to our model spashscreen
Why a family?
We use a simple legend.
Thu, Jun 13, 2013 at 9:32:09 AM | Adding a General Notes section to our model spashscreen
MEBDesign
We are fairly new to it all and we were suggested using elements from the AEC standard template. So we have basically taken this template file and tweaked it to our needs. So we are using a tweaked version of the spashscreen in this which is a family. Forgive me, I don't really know at this stage what the alternatives are to this.
How would I go about doing this as a legend?
Thanks
Simon
Thu, Jun 13, 2013 at 9:48:17 AM | Adding a General Notes section to our model spashscreen
In your template, simply under view - select legend - name it and add whatever you want.
Save the file with this view picked as thumbnail preview under the save options.
Thu, Jun 13, 2013 at 10:03:03 AM | Adding a General Notes section to our model spashscreen
MEBDesign
OK, I got it! We had the spashscreen working fine, just meant how did you intend to use the legend on it, but I understand now and so have imported that legend onto the spashscreen view so notes can be added.
Great, many thanks both!
creating General Notes (best practices/ efficient methods) 2017
Fri, Nov 17, 2017 at 4:37:26 PM
Importing General Notes
Wed, Feb 9, 2011 at 8:08:30 PM
Typing General Notes
Mon, Sep 20, 2010 at 1:32:40 PM
General notes & vent calcs
Tue, Oct 11, 2005 at 6:15:05 PM
justification problems creating general notes.
Mon, Sep 21, 2015 at 9:24:20 AM
Page generation time: 1.4935
