89 Users Online (88 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Revit MEP Differences
Wed, Jun 12, 2013 at 7:59:44 AM | Revit MEP Differences
TGarner
I have some experience with Revit 2013 from college, but my employer has Revit MEP 2011. I am having issues with getting elevations and 3D views to appear realistic. Walls appear white with gray outlines. Is this the best I can get with MEP? I have tried assigning materials and editing colors and textures, but no results. Also, when I export to AutoCAD I can edit appearances to my heart's content. Mechanical components appear fine, which is why I'm assuming it is an issue with the software version I'm using.
Wed, Jun 12, 2013 at 8:08:16 AM | Revit MEP Differences
Your problem is not the software - it is mostly process error.
MEP does have different settings.  Try changing your view to coordination.
Wed, Jun 12, 2013 at 8:13:17 AM | Revit MEP Differences
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Is your visual style set to Realistic?  Are there any visability graphic overrides?  My main assumption is that your discipline is most likely set to Mechanical, if you change it to Architectural or Coordination I bet it looks correct.  Images of the problem are always helpful
Wed, Jun 12, 2013 at 8:25:19 AM | Revit MEP Differences
TGarner
That did it - thanks!
Revit MEP 2009 Rendering
Thu, Mar 5, 2009 at 8:35:55 PM
Understandinf the differences between worksets and linked projects
Mon, Aug 6, 2007 at 6:32:58 AM
Revit MEP or AutoCad MEP
Fri, Oct 14, 2011 at 8:21:49 AM
Revit MEP
Wed, Oct 28, 2009 at 10:10:40 PM
From 2D CAD MEP files to Revit MEP
Tue, Feb 9, 2010 at 11:12:10 AM
Page generation time: 16.8673
