47 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> WORKSET CAN'T CREATE IN DIFFERENCE SUITE SET
Tue, Jun 11, 2013 at 5:06:57 AM | WORKSET CAN'T CREATE IN DIFFERENCE SUITE SET
sagboy
We have Revit building suite 2014 and Revit architecture 2014
Both of them can't work in the same work set?
i create workset in server(Create from Revit building suite2014) and when my another usewr is use Revit architect2014
try to create a new local file from central file. The Revit is cannot select or create local file.
In the same way i try to start from Revit arch for central file first the revitbuilding suite is can't create a new local file too.
Have anyone know do i do something wrong?
Tue, Jun 11, 2013 at 8:40:57 AM | WORKSET CAN'T CREATE IN DIFFERENCE SUITE SET
I doubt that you will find many users here that have this combination.  I suggest you contact your retailer and AutoDESK diirectly.
Default Workset
Sun, Sep 25, 2016 at 12:01:19 AM
Workset being borrowed by someone who's not even in the office?!?
Tue, Apr 24, 2007 at 9:25:53 AM
BIM Manager Suite
Wed, Jul 2, 2014 at 7:38:51 AM
Any way to set up certain workset to be gray?
Wed, Dec 8, 2010 at 3:23:01 PM
Autocad Architecture join the Revit Architecture Suite
Tue, Aug 19, 2008 at 9:14:56 AM
Page generation time: 1.9960
